Minneapolis Moline Tractors Discussion Forum
Why is my R so noisy
MM1
08-13-2005 05:14:59
I have a 1945 R it runs real nice but the bottom of the engine is very noisy everything looks good any idea's.
BMG
08-14-2005 19:09:54
 Re: Why is my R so noisy in reply to MM1, 08-13-2005 05:14:59
MM1,
The R engine has a flat roller bearing in the front and a shell thrust bearing in the rear. The front roller bearing will get rusty and pitted from sitting a long time. This is usually where most of the growl comes from in an R engine. Unfortunately you have to pull the crank to replace the front bearing. One other thought. Did you check the governor? It's not uncommon for the governor to be so worn or out of adjustment as for the flyweights to hit the governor casting. Have you checked the rod bearing clearances? Throwing a rod can make a big mess of the bottom end....
Brian
H Reiner
08-13-2005 17:34:18
The R crankshaft has rear and front ball bearings and if they sit for a long time the races can get pitted from rust. and they can make a growling noise. If they are really bad the front pully will move back and forth when the clutch is pushed in. New bearings are about $300 each unless you can find NOS then they should be about $100 each.
