Minneapolis Moline Tractors Discussion Forum
Tranny change
ZinMN
08-10-2005 19:13:49
I was going to change my tranny fluid in my Z i was told by someone to drain the fluid then dump in the same amount of diesle run it around the block and drain again its supposed to clean it out good idea or bad
Mopower
08-11-2005 10:06:33
 Re: Tranny change in reply to ZinMN, 08-10-2005 19:13:49
It works as long as you don't put much of a load on it or work it hard. I put ATF in mine because that stuff is high in detergents and can keep stuff clean...mixing would work too. No harm done, just don't work it hard. It just needs to slosh around in there some.
