Minneapolis Moline Tractors Discussion Forum
335 p/steering
Bruce Mitchell
08-07-2005 07:39:57
Need some advice.I have a 57 335 industrial with p/st ,3 pt backhoe and frt loader.The ps pump is
on the back of the hyd pump that feeds the implements.I want to sell hoe and loader but fluid reservoir is inloader frame.If ikeep hyd and strg pump what could i use as a res.Also there is possibly a problem with steering since
someone took lower gear out of p/st pump so ihave no power anyway.Could i just loop the two lines together and forget the power thanks for any advice
Chuck S.
08-07-2005 12:57:58
 Re: 335 p/steering in reply to Bruce Mitchell, 08-07-2005 07:39:57
You could loop the lines together,or remove them. I have a hyd res with 3 remotes for 335. that I removed from mine.
Bruce Mitchell
08-07-2005 17:03:14
 Re: 335 p/steering in reply to Chuck S., 08-07-2005 12:57:58
ChuckS Thanks for the advice Iwasnt sure looping the lines would work. Thanks again
