Minneapolis Moline Tractors Discussion Forum
1944 zts
elmer jesok
08-06-2005 12:42:42
2 questions I HAVE OVERHAULED THE ENGINE, MAG HAS BEEN REBUILT THE ENGINE RUNS ON THREE CYL AT IDLE THE SECOND I LUG THE ENGINE THE FOURTH CYL FIRES I HAVE CHECKED THE COMPRESSION THE SPARK THAT SEEMS GOOD, ANY SUGGESTIONS? WHAT WOULD BE THE CORRECT REAR RIMS IT HAD 10-38 ON IT PRESS STEEL RIM THANKS EJ
havvey
08-07-2005 05:43:18
 Re: 1944 zts in reply to elmer jesok, 08-06-2005 12:42:42
fmm is correct you can use ether also to find a leak. A weak valve spring will also cause this problem and won't show up on a compression test. seems 10/38 is correct mm z's did have a cast rear wheel too i believe.
08-11-2005 19:18:12
 Re: 1944 zts in reply to havvey, 08-07-2005 05:43:18
THANKS the weak spring WAS the problem
Kelvin
08-06-2005 19:50:36
Have you tried that sparkplug in a different hole? I had that problem a couple weeks ago, for some reason both cylinders would fire when I swapped plugs. They Were NOT Champion plugs, either.
About 10 years ago I had a U that did similar, would miss at idle, not noticeable when reved up or under load. Finally pulled the head off and the exhaust valve seat had a groove in it.
F M-M
08-06-2005 19:30:48
Check for an intake leak on that cylinder. If the gasket isn't tight or cracked, it will suck air but under load and at higher rpms they will usually hit. Try an oil can on the gasket to see if it sucks in the oil. I've had this happen.
