Minneapolis Moline Tractors Discussion Forum
10A4232 Heads
G Brown
08-05-2005 12:22:08
I have a set of 4232 heads that leak on the exhaust valves on a pressure check. Can they be repaired? They came off a running tractor that didn't appear to have any problems. Or do they all leak?
Andy2
08-06-2005 17:52:14
 Re: 10A4232 Heads in reply to G Brown, 08-05-2005 12:22:08
If they leak around or between the valve seats they should be repairable. If it's around the sparkplug hole or under the valve it can be difficult.
F M-M
08-06-2005 19:34:00
 Re: 10A4232 Heads in reply to Andy2, 08-06-2005 17:52:14
What does it cost to get them repaired? I have 2 off a vista that leaked on the pressure test between the valves. Will they hold?
Andy2
08-08-2005 19:37:59
 Re: 10A4232 Heads in reply to F M-M, 08-06-2005 19:34:00
My Dad had a 4210 head repaired a year ago and I think it was around $100. Take it to any automotive machine shop and they will most likey send it to a shop that specializes in fixing heads.
gbb
08-07-2005 16:25:26
What kind of pressure is used for checking heads? 40 lbs?
