Minneapolis Moline Tractors Discussion Forum
MM Transmissions
MMDave
08-02-2005 16:45:28
Ok, Guys this is a tough one. Do any of you know what the differences are between a G1000 Wheatland transmission and a M670 Super transmission? I am trying to put a 670 Trans in a Wheatland and I am wondering what it would take to make them fit. They appear to be the same, But the part number is different.
CBGS
08-03-2005 06:36:24
 Re: MM Transmissions in reply to MMDave, 08-02-2005 16:45:28
Why would you want to go and do something like that??? Just break down and get another wheatland trans.....
dirtjockey
08-03-2005 06:26:54
the G900/g950 and the 670 shared some tran components. they also shared the same components with the g1050 and g1350. the M670 by design has a heavy duty transmission, But different torque. Its easier to derate a tractor then to uprate one
MMDAVE
08-03-2005 06:58:35
 Re: MM Transmissions in reply to dirtjockey, 08-03-2005 06:26:54
Do you believe that the components from a G1000 Trans will fit into a M670 case?
dirtjockey
08-03-2005 10:08:09
 Re: MM Transmissions in reply to MMDAVE, 08-03-2005 06:58:35
I researched this once, but will need to get all my books together again. If I remember correctly the M670 top shaft is different for the torque but that most of the rest of the gears correlate to either the G900 and G1350 lines. MM did not make diffent transmissions for every tractor. The ring and pinion is the same on all 50 series tractors.
je
08-02-2005 18:11:23
Why would you do that? the 1000 trans was not heavy enough and you are going to put a 670 in it? hope you don`t want to use it!!!!! !!!!! !!!!!
MMDave
08-02-2005 19:40:59
 Re: MM Transmissions in reply to je , 08-02-2005 18:11:23
The reason I was asking is I suspect the 670 trans and the G1000 trans were both basically the same.
JoeMN
08-02-2005 20:34:38
 Re: MM Transmissions in reply to MMDave, 08-02-2005 19:40:59
I would be surprised if they are the same. G1000 transmissions were upgraded several times during their production run. If you are going to all the work of replacing a transmission why wouldn't you put the strongest,up to date transmission you could find in your G1000? Or are you going to take out two pistons so you have the same power as a 670?
MMDave
08-03-2005 05:30:08
 Re: MM Transmissions in reply to JoeMN, 08-02-2005 20:34:38
I actually was wanting to use all the G1000 components, but just the M670 case.
