Minneapolis Moline Tractors Discussion Forum
minn. moline tractor
Bruce24
07-31-2005 17:26:16
Could anyone help us????
We are trying to find out the year and maybe even worth of this tractor that we found on our grandmothers land. All we have are the numbers on the block and the model number. It says that the model number is matched up with the RT series, but the model number on the tractor says RTU. It says it places it about 1948.....this is all I have: Minn. Moline Model no. RTU Serial no. 417 073u
on the block is the numbers Re 101-A( on one side) and on the other side it reads: 12 Re 101-A
if you know of this tractor could you please let us know? Thanks!!! Bruce
1951 RTU
08-06-2005 07:02:35
 Re: minn. moline tractor in reply to Bruce24, 07-31-2005 17:26:16
1947 is the year.
Linda South
12-03-2005 22:39:13
 Re: minn. moline tractor in reply to 1951 RTU, 08-06-2005 07:02:35
where might I find a oil and grease lube chart for this tractor??
havvey
08-01-2005 13:46:11
I don't have a book in front of me for the numbers but a modle R great little tractor there were many options unrestored less than a $1000
old
07-31-2005 19:19:54
That would be a model RTU. Should be a trike type tractor. One of the small MM tractors. Depending on the tires and sheet metal, and it its locked up it could be worth from around $200-1500. The higher part of the price would be if the tires are good and it has all the sheet metal and thats good also and it runs.
