Minneapolis Moline Tractors Discussion Forum
8 Volt battery
Chrisfromsolitude
07-30-2005 14:54:09
Can I just put an 8 volt battery on my ZAU? Will I have to put a resistor in for the 6volt coil or points? Do I have to turn the gen. up to 8 volts or will it work on 7.5? Thanks for any info.
R MMs
08-02-2005 12:47:57
 Re: 8 Volt battery in reply to Chrisfromsolitude, 07-30-2005 14:54:09
I agree with the guys leave it 6 volt and use big cables. NAPA make a battery #5019L group 19L that is very close to a 2L. It has a few less cranking amps but it works well in Ohio winters and fits under the gas tank much better than a group 1.
shoeie
08-01-2005 21:08:34
I put an eight volt in a Farmall a number of years
ago and it worked just great, I had to set up the regulator a bit but it spun like a 12 volt. Did
the sme in a 49 studebaker truck, work just fine in it too.
Harry , Ohio
08-01-2005 21:05:06
Along these lines I am really having trouble locating a group 2L 6 volt battery. Does anyone know of company that makes them or where available?
mike nassif
07-31-2005 08:15:46
An V battery replacement is usually resorted to by a lazy technician. IF you have a large enough cables, & IF your starter is good, & IF you have THOROUGHLY CLEANED ALL OF THE GROUND CONNECTIONS, then your 6 V will work just fine. Clean connections & VERY heavy cables are the most important.
Texas Denny
07-31-2005 07:18:32
I expect your reason for switching is slow cranking. My experience says to put your money in big cables and stay with 6 volt. I paralleled two 1 AWG (couldn't find 0 AWG or 00 AWG) on my 1952 Ford car and now the V8 spins like it is on 12 volt. Two 1 AWG are equivalent to 000 AWG. The previous owner had 8 volt on it with the wrong cables so it still didn't start good. But the 8 volt system wrecked half of my gauges and nearly everything else electrical. If you are going to change (I recommend better cables and stay 6 volt), go all the way to 12 and make all the fixes to the electrical system.
sms
07-31-2005 05:39:22
It has been mentioned many times but once more can't hurt. A 6 volt system requires twice the amperage of a 12 volt, USE HEAVY BATTERY CABLES! cables that are to light guage will cause slow cranking. good luck
John T
07-31-2005 03:58:28
Chris, I normally hang out over on the JD board but was here cruising. Im NOT a fan of 8 volt systems cuz if youre gonna convert anyway and want her to start a lot stronger, go ahead and convert to 12 volts. The VR would have to be recalibrated to work the best at 8 volts,,,,, ,you should run a series external ballast ahead of the coil to reduce the coils input voltage to around 6 to avoid premature points burn up plus not overheat the coil.
John T Retired Electrical Engineer
teschmitz
08-01-2005 05:33:34
 Re: 8 Volt battery in reply to John T, 07-31-2005 03:58:28
John,
It is good to see you on the MM side. I monitor the JD side just to gather some of your electrical knowledge.
John T
08-02-2005 06:06:29
 Re: 8 Volt battery in reply to teschmitz, 08-01-2005 05:33:34
Hi tes, the problem is I gotta stick to theoretical versus practical/experience in this foreign territory since Im unsure of the systems n details.
John T
Alan K
07-30-2005 20:59:50
MM had a service bulletin on this very thing. They did not recommend doing it. It will raise havoc with your electrical system.
old
07-30-2005 19:19:35
Why would you want to go with a 8 volt battery in the first place??? And yes you would need to do things with the reg and maybe put a resistor in line with the coil. Why not just stay with 6 volts or if you need to upgrade to 12 votls instead of not going the right way
