Minneapolis Moline Tractors Discussion Forum
Point Gap/Effects on Operation
JKC
07-27-2005 13:03:02
Can someone explain to me how an older gasoline tractor engine (12-volt) runs when the point-gap is set to close? To far apart? Can either extreme make the engine stop running completely after about 30 seconds, or would it be more likely to not start in the first place?
Thank you.
Kelvin
07-30-2005 05:07:42
 Re: Point Gap/Effects on Operation in reply to JKC, 07-27-2005 13:03:02
If I recall correctly, when the points closed up on the 335 it got really sensitive on the fuel mix, and developed a real tendancy to skip when the governor opened up.
The points had worn to the point the metal frame around the rub block actually wore grooves in the distribuitor cam and I had to polish it. It may have skipped because it was shorting to the cam and actually the cam/point arm contact changed the timing of the spark.
