Minneapolis Moline Tractors Discussion Forum
Super 4 Star clutch problem
Ron Winship
07-25-2005 18:35:05
I wondered if my tractor slips in high range is it my main clutch or the ampli-torque. It works fine in low range. Thanks
Chuck S
07-25-2005 20:11:37
 Re: Super 4 Star clutch problem in reply to Ron Winship, 07-25-2005 18:35:05
When you shift into high range of a/t does lever snap in. Should take app 20to 35 lbs to ingage high range. Also does it slip in any gear in high range under load.
Ron Winship
07-28-2005 19:07:53
 Re: Super 4 Star clutch problem in reply to Chuck S, 07-25-2005 20:11:37
The lever snaps in fine on the a/t. I checked it with a pull scale. I am going to have it out tomorrow I will check to see if it slips in all gears.
