Minneapolis Moline Tractors Discussion Forum
Gear shifter slop
Melvin
07-24-2005 16:16:09
I need help guys. I am restoring my 51 za. I have a ton of excessive shifter twist and slop. Will not go into the gears all that well. Was thinking about taking out and welding both sides of the shifter ball. Or should I try to replace the pin? The pin looks like it may not come out. Will it? THANKS IN ADVANCE!!!!
Kelvin
07-27-2005 13:31:28
 Re: Gear shifter slop in reply to Melvin, 07-24-2005 16:16:09
On a ZAS I worked on, I welded the ball (The groove was worn) and I also replaced the pin. I got a new grooved pin from my JOhn Deere dealer, and cut it to fit.
Alan K
07-24-2005 20:17:51
Yes the pin will come out, it did on mine anyway. I took mine out and turned it 1/4 turn. This will make a big difference. You may have excessive wear on the end of the shift lever also. May have to build that up if the other doesn"t solve the problem.
