Minneapolis Moline Tractors Discussion Forum
water pump and clutch
Sellerd
07-21-2005 16:45:47
I have a MM 4 Star. The water pump went out. Any idea where I can find one or somebody who rebuilds them.
The clutch on the 4 Star needs to be set (gear grinding). The foot petal apparently had broke in the past and the former owner welded it (unk. if correctly). I have re-threaded the adjustment rod w/o any improvement in smooth shifting. I am told there is a setting somewhere on the side to make adjustments (but that is all the person knew) ??
ANY HELP WOUILD BE APPRECIATED.
R.D.F.
07-22-2005 04:58:42
 Re: water pump and clutch in reply to Sellerd, 07-21-2005 16:45:47
We stock brand new water pumps for these tractors, no core charge either. 920 295 3278 or [email protected], Dale
Kelvin
07-21-2005 18:51:48
That clevis on the threaded rod is all the external adjustment there is on the clutch.
I rebuilt my own pumps. I got the shaft, bearing and seal from Welters 417-498-6496. They even sent me an instruction sheet for installing it.
I have heard about some NAPA stores being able to send a pump out for repair, I never did this myself.
