Minneapolis Moline Tractors Discussion Forum
mounting a flywheel
mm boy
07-21-2005 07:26:40
Will a 335 Flywheel fit on a u302 or a 445 crank? Or is there some work involved to mount the flywheel? Thank you for your help Erik
Kelvin
07-21-2005 08:47:56
 Re: mounting a flywheel in reply to mm boy, 07-21-2005 07:26:40
I think the 335 will interchange fine with the 445.
For the U302, I think you may also have to use the 335 pto shaft drive flange. If I recall correctly, the pto shaft drive flange for a U302 goes on the crankshaft studs first, then the flywheel, while the flywheel mounts, then the pto drive flange on the 335 and 445.
