Minneapolis Moline Tractors Discussion Forum
MM 670Super LPG Choke
herald
07-20-2005 20:42:08
I have a MM 670 Super LPG with Ensign carb. and suddenly it won't run or even attempt to start unless the choke is pulled all the way out. Could the butterfly have slipped on the choke shaft? Any other ideas ? Thanks for any thoughts. Herald
Roger in Ks
07-22-2005 05:18:57
 Re: MM 670Super LPG Choke in reply to herald, 07-20-2005 20:42:08
Take the cover off where the choke rod goes throught the carb. There is a chance that the rod that holds the tear drop shaped choke is bent. The choke is on when it is in the off position. Gunk builds up in this area and needs to be cleaned to keep this from happening.
herald
07-23-2005 07:21:02
 Re: MM 670Super LPG Choke in reply to Roger in Ks, 07-22-2005 05:18:57
Roger in Ks, I cleaned it up and that fixed the problem. Thak you. Herald
