Minneapolis Moline Tractors Discussion Forum
ZA Carb Sweat
Todd Johnson
07-14-2005 15:27:40
Just rebuilt my ZA carb. It is a tsx-97. The thing starts to sweat afer a few minutes of running. What do I have wrong?
Ks-farmer
07-15-2005 08:22:32
 Re: ZA Carb Sweat in reply to Todd Johnson, 07-14-2005 15:27:40
Your tractor should run stronger too if you have an Lp manifold. The cold air is more dense and will expand more which gives more power.
Kelvin
07-14-2005 18:14:32
Nothing wrong. They just do that, and worse when the humidity is high.
As long as your tractor has a gasoline or Kerosene manifold you shouldn't have any problems.
The gasoline/Kerosene intakes are usually fastened to the exhaust manifold so they transfer a bit of the exhaust heat to the intake, to minimize frosting. LP manifolds frost a lot worse because they don't touch the exhaust manifold.
BLT
07-14-2005 18:12:35
You have done nothing wrong, you probably have an lp manifold on it . The gas heats up on a gas manifold where it can't on an lp. It will run just fine, the manifold throat on my 206 will actually frost up sometimes, I use it for pulling with no problems.
Mike logan
07-16-2005 01:23:55
 Re: ZA Carb Sweat in reply to BLT, 07-14-2005 18:12:35
Mine frosted one day.That was the first time I ever got 1 st place
