Minneapolis Moline Tractors Discussion Forum
Propane to Gas Conversion
Ted S
07-12-2005 17:00:31
I have a model M670 currently outfitted for propane. I need to know the steps to convert to gasoline.
Ks-farmer
07-13-2005 14:31:13
 Re: Propane to Gas Conversion in reply to Ted S, 07-12-2005 17:00:31
You are better off with propane, it keeps your oil cleaner which makes your tractor run longer. If you still want to change you will need to run Premium unleaded gasoline if you are going to keep the heads. If not you will need to change them to get a lower compression. Find a different gas tank or use the old one and refit it. Then you need to close off the water ports on the water pump and upper water manifold. Last but not least find a big enough carburetor and copper or gas safe rubber hose and fittings to go from the tank to filter and carburetor.
