Minneapolis Moline Tractors Discussion Forum
mm Model EE
MM1
07-09-2005 16:25:54
Does any one know anything about a model EE? How many where built,how many horse, Anything. Thank's
MM1
07-09-2005 19:04:31
 Re: mm Model EE in reply to MM1, 07-09-2005 16:25:54
On the serial tag it is model EE serial #410796 if it is a R it would be a 1945 Why dont they have model R in place of the EE? Thank's for the input
ILL John
07-09-2005 19:39:11
 Re: mm Model EE in reply to MM1, 07-09-2005 19:04:31
The tag you're looking at is the engine serial #, like Kelvin said, there is an identical tag on the TRANSMISSON which will have the tractor serial #. Hope this helps, John
Joe Leising
07-09-2005 19:38:46
I think if you look at the serial tag that is on the side of the transmission you find that it has the model R. The tag you are looking at is just for the engine as MM used the same engines for tractors and stationary power units.
Joe
Kelvin
07-09-2005 18:13:50
The EE was the engine used in a Model R tractor. there should be a serial tag on the right side of the transmission case.
MM1
07-10-2005 05:31:50
 Re: mm Model EE in reply to Kelvin, 07-09-2005 18:13:50
Thank's Guy's, I was looking at the wrong tag and had never seen a EE befor. Thank's again
