Minneapolis Moline Tractors Discussion Forum
TSX-97 Carb. He-ll
Jerry Cent. Mi.
07-07-2005 17:53:10
I finally got the Z that I bought as a basket ready to run but it would only run at an idle. I cleaned the cab. twice now and installed a repair kit but still have the same result. I now know the tractor runs good as I jury rigged a carb. from a Cockshutt-40 and it runs good. The TSX-97 carb is what it requires and I would like to use the right carb. as the cockshutt carb. can't be connected to the govenor. Anyone out their good with these or have a good one for sale? Jerry
ILL John
07-07-2005 19:48:19
 Re: TSX-97 Carb. He-ll in reply to Jerry Cent. Mi., 07-07-2005 17:53:10
Send it to Matt Gall, Motec Eng., he'll rebuild it, test it on an engine, and paint it, $75.00. He does the best work, least cost, quickly. IF you disconnect yours from the governor, does it run like the Cockshut? Just asking, the governor might be the culprit, OR the linkage might be binding. Those are critical. He also rebuilds the governors for $75.00. Slop in any of the shafts can contribute to the problem, maybe the link is bent wrong by the previous owner, an owners manual will tell you how to set up the linkage. Hope this will help. John
