Minneapolis Moline Tractors Discussion Forum
MM GB block HELP!
Tracy Redd
07-07-2005 00:36:15
Tonight i was trying to get blocks off crankcase housing. I got one off but i couldn't get the other block off!!!. I tried work it for two hrs. and i can;t get the block loose! I heard the it suppose to be easy get the block off. I had all stud bolt off but one stud bolt couldn't get it off. Is there any way to get the loose? Why it's so hard get block loose?
Please help me
Thanks
Tracy
wgm
07-11-2005 18:38:46
 Re: MM GB block HELP! in reply to Tracy Redd, 07-07-2005 00:36:15
Tracy,
Don"t know if this will help but I had the same situation removing one the blocks on my UB. I used a block of wood and a hydraulic jack from underneath up through the crankcase and pushed up against the block. Broke it loose in no time.
1951 RTU
07-07-2005 19:45:14
I know on my 51 R I had a heck of a time. finally I used 6 flat bladed regular screw drivers and gradually worked the block off. I had tried everything else.
Ks-farmer
07-07-2005 07:54:47
Are the rod bolts all undone or pistons out? Is the tractor stuck?
Tracy Redd
07-07-2005 09:26:36
 Re: MM GB block HELP! in reply to Ks-farmer, 07-07-2005 07:54:47
Yes I took all rods and pistons out. Tractor is not stuck. The reason i am trying get block off becase i saw either crack or scratch on cylinder wall. So i can it to machine shop to check it.
There one cylinder head stud bolt can't get it loose. The bolt is same place where the block that i can't get it loose.
Thanks
Tracy
MIB 22
07-07-2005 15:07:30
 Re: MM GB block HELP! in reply to Tracy Redd, 07-07-2005 09:26:36
If it is one of the studs that goes through the water manifold on top they can get rusted up pretty tight. Usually take a big pipe wrench and get the stud out first if you can.
scottthomas
07-09-2005 08:06:39
 Re: MM GB block HELP! in reply to MIB 22, 07-07-2005 15:07:30
MIB-I also am having similar problems and others (ugh!) with a GB I'm restoring. I left my email open, could you email me yours so I could ask more questions? If you'd email your phone number back, that'd be ideal, cause I could call you on my dime and go thru my list of questions! Your help would be much appreciated! Have a nice day!
Jerry Cent. Mi.
07-07-2005 17:17:37
Some times they are very difficult. I have a chisal that I have ground to a sharp edge and thin like a putty knife that gradually gets thicker. Some guys seal both sides of their gasket and the jugs are like welded down. Take it easy with the chisal. I usually start where the jug is rounded. Jerry
