Minneapolis Moline Tractors Discussion Forum
UO disc harrow parts
Jason VDB
07-03-2005 09:40:03
I need some help locating parts to what I believe is a UO disc harrow, though I may be wrong on the model it is definately an MM 8ft wheel disc. What I am in need of: bearing carrier assembly both halves. I am having all new wood bearings made but I noticed that one of the carriers has been severely damaged and is missing about half of its normal width. I also need bracket that connects the bearing carrier to the disc frame. I believe these have been called "towers" by some manufacturers. These are the two most important parts I need but if someone were parting out a disc there are some other parts I could use as well. These discs do not seem to be real common in Southwest Michigan and nobody around here seems to ever remember seeing MM discs. Any help would be greatly appreciated. Thanks
Cliff Nelson
07-05-2005 19:57:57
 Re: UO disc harrow parts in reply to Jason VDB, 07-03-2005 09:40:03
Whar are the part # cast on the bearing holders? We may have a couple NOS parts if we can identify them with a number.
Leroy
07-05-2005 04:28:06
I think Skilling's Tractor Parts at North Hampton, Ohio may have your parts as they did have one they were parting out. North hampton is 12 mile northwesr of Springfield, Ohio on S R 41 and is one of those if you blink you will miss it towns. I think if you do a search for tractor parts yard you can get there phone number. I am close enough I just drive instead of calling
Kelvin
07-03-2005 17:49:56
I'm looking for about the same parts for a model HA.
Give Don Rice a call: 585-243-2617. He has some disk parts, but they weren't the boxes I need.
IL John
07-03-2005 19:27:59
 Re: UO disc harrow parts in reply to Kelvin, 07-03-2005 17:49:56
The UO disc is very distinct, it has a 4" pipe bent in a wide "u", to which the wheels are attached.
IL John
07-03-2005 19:27:43
