Minneapolis Moline Tractors Discussion Forum
hydraulic reservoir
ZinMN
06-30-2005 19:18:03
coming off my hydraulic reservoir at wher i think the fill plug is supposed to be ther is a small metal tank about the size of a 2 litre bottle and i am wondering what it is or does
ZinMN
07-03-2005 12:00:06
 Re: hydraulic reservoir in reply to ZinMN, 06-30-2005 19:18:03
1950 ZAU not 48 my bad
ZinMN
07-03-2005 08:44:58
IT is a modle Z or ZAU 1948 or so we figure if im right
Bob M
07-02-2005 19:49:22
My UTU has an aux hydraulic tank pipe up like you describe. The fitting the top of the tank says "Stewart Warner" and "Vacuum Reservoir" - obviously it was added by the PO.
However on mine the tank is connected to the reservoir only with a small (1/4") tube - no way it would flow enough to handle an oversize cylinder. Suspect rather it was a "band aid" added to provide a couple quarts of extra reservoir capacity to compensate for a slow leak somewhere.
Punch below for a pic...
Kelvin
07-02-2005 19:22:50
It sure would help to know what model tractor. Assuming your tractor is a late R, a Z, ZA ZB U, UB or G series, that tank was probably added to increase the fluid capacity of the system. The regular reservoir is fine for the standard 8 or 10" stroke cylinder, but might not have enough capacity for a loader, especially if the cylinders are single-acting.
Ks-farmer
07-01-2005 21:25:19
You didn't mention what tractor. I'm assuming that what you are talking about is the canister for your hydraulic filter.
