Minneapolis Moline Tractors Discussion Forum
Splitting a ZAU
Jerry Cent. Mi.
06-17-2005 13:44:25
Looks like its necessary to split the Z and replace the crank seal amd might as well replace the clutch disc while I am at it. After I support the rear end with blocks I plan on picking up the back of the engine with my cherry picker and move it away from the the rear section. Its a tricycle and I am concerned about it tipping over. Should I get another picker to support the front of the engine? What have others experienced? Thank You.
Jerry Cent. Mi.
06-17-2005 16:30:34
 Re: Splitting a ZAU in reply to Jerry Cent. Mi., 06-17-2005 13:44:25
Amazing what a little thought will do. I will try to find a balance point to pickup from. Jerry
Mike Logan
07-16-2005 02:18:09
 Re: Splitting a ZAU in reply to Jerry Cent. Mi., 06-17-2005 16:30:34
what I did was support the rear and with my cherry picker raised the front slightlywith my chain attached to the motor. removed the radiator and front end then removed the engine
Kelvin
06-18-2005 10:07:53
What we did with the ZB was to chain the front to the rafters, support the rear of the engine, put the bell housing on a dolly that had a bottle jack bolted to it and roll the back end away from the front.
