Minneapolis Moline Tractors Discussion Forum
445 oil filter bolt
ted regentin
06-12-2005 18:31:57
Does anyone out there have or know where I can get an oil filter canister bolt, the one that is hollow and goes through the center of the filter. I changed the oil on mine and I had a small leak, so I tightened it and the bolt broke off. It had already been repaired once. I welded it and it holds, and still leaks a little at the sealing washer.
Kelvin
06-13-2005 09:13:27
 Re: 445 oil filter bolt in reply to ted regentin, 06-12-2005 18:31:57
You probably need a new washer too.
wendell Everett 740-922-3335. Welters 4174-98-6496
flyrod
06-12-2005 19:00:36
Try Les Wenzell,Wendell Everette or Welters.They are on the mm.com website under parts.
