Minneapolis Moline Tractors Discussion Forum
Shaving an M5 head down, how much will it help?
Nate K
06-10-2005 18:56:03
I have an M5 gas that had a blowed head gasket, while I have it apart I am going to knock the heads down an 1/8 of an inch. I was wondering if this will give it as much compression as a set of LP heads or not and about how much HP I should expect to gain. Thanks
R.D.F.
06-11-2005 05:29:02
 Re: Shaving an M5 head down, how much will it help in reply to Nate K, 06-10-2005 18:56:03
You"re not telling us much here about what your objectives are with this tractor, but I presume you"re planning on pulling it, right? If so, while these heads are off, there many other ways of building USUABLE pulling power. Pulling requires Usable pulling power to get past your competitors. Between Doug and myself we have combined 54 years of pulling experience, and high compression alone ain"t gonna get er done. Dale
Gator Mouth
06-16-2005 18:04:23
 Re: Shaving an M5 head down, how much will it help in reply to R.D.F., 06-11-2005 05:29:02
Ok tough guy, then where do we get the usable "pulling power"??? Dont just dangle it in our faces...
Augie
06-20-2005 09:01:51
 Re: Shaving an M5 head down, how much will it help in reply to Gator Mouth, 06-16-2005 18:04:23
You ain't gonna catch many flies with vinegar...
R.D.F.
06-22-2005 17:36:52
 Re: Shaving an M5 head down, how much will it help in reply to Augie, 06-20-2005 09:01:51
I apologize for not answering sooner, been real busy at the shop and our pulling season started last weekend with 2 events and we"re preparing for Tomah at this moment. To get usuable pulling power on a N.A., stock rpm tractor, you have to make those cylinders vacuum every ounce of fuel and air(oxygen) you can direct to them. Maximize the flow capabilities completely, keep the fuel-air(oxygen) in the cylinder as long as possible while developing a loooong, slooow explosion and you are on the way to real usuable pulling power. There are innumerable ways to accomplish this goal. Keep these basics in mind and let your imagination run wild and it can be more fun building than driving, well maybe. May the full pull force be with you, Dale
