Minneapolis Moline Tractors Discussion Forum
Information
Robert McKay
06-10-2005 10:33:44
I have access to a minniapolis Moline tractor. Serial # 0085000154 Model 7AN. (I wonder if that's ZAN.) Engine 3 3/8" X 5" Bore and stroke Engine serial # 0185001404
The tracror is located near Reno NV at a glider port when it was used to pull a drag clearing brush and an olf flail mower. It was running well up to about 2 years ago when the battery died. It was set aside and is just taking up space. Does it have any value as an antique. It is possible that if anyone loves They could have it by hauling it away. Any info would be apreciated.
1951 RTU
06-10-2005 18:51:41
 Re: Information in reply to Robert McKay, 06-10-2005 10:33:44
S/N prefix 008 =ZAN Tractor w/206B-4 Engine.
0085000154 = 1950 ZAN
RYAN BLAND
06-10-2005 13:06:11
i have seen them bring $3200 and also go as low as $200, it more or less depends on whether or not the motor is stuck, how the sheet metal looks,and how much it has been barn rigged, if the metal is good, tires are good (the most expensive retoration part), if it runs, and you can more or less get it for a hand shake you won"t have a hard time spending a little more, good luck and have fun
