Minneapolis Moline Tractors Discussion Forum
How many vista G-1000 were made diesel and LPG
mlansing
06-04-2005 14:23:41
Just wondering how many Vistas were made and how many where lp gas and about how many diesels?? Are this tractors collectable?? are they hard to find parts for ?? Let me know. I have found Two with very low hours both need work but are striaght and one is diesel and the other is lp gas.
THanks
Matt Lansing [email protected]
1951 RTU
06-04-2005 15:14:24
 Re: How many vista G-1000 were made diesel and LPG in reply to mlansing, 06-04-2005 14:23:41
MM G1000 VISTA LP GAS 1967-1969. 67=290,68=100,69=174
MM G1000 VISTA DIESEL 1967-1969.
67=721,68=450,69=425
Does it have front wheel assist? There were a few made with front wheel assist.
Dieselbear
06-05-2005 04:52:18
 Re: How many vista G-1000 were made diesel and LPG in reply to 1951 RTU, 06-04-2005 15:14:24
how many were made striaght gas?
BMG
06-05-2005 17:00:34
 Re: How many vista G-1000 were made diesel and LPG in reply to Dieselbear, 06-05-2005 04:52:18
It's unknown how many gasoline G1000 Vista's were produced. Very few seems to be the concensus. The serial numbers would be the same as LP vesions. The parts book for the Vista doesn't even show gasoline equipment. The earlier G1000 row crop parts books shows gasoline equipment and there were very few made.
Brian
1951 RTU
06-05-2005 06:14:42
67-69 = 721+450+425
mlansing
06-04-2005 16:03:59
No fWA but they both are under 1800 hours and both have been sitting for about 20 years, tin work is excellent and orginal tires. The lp I is the closest and the guy wants me to make an offer what are worth. The Diesel is more convent for fuel but I think it needs more work.
Matt Lansing
F M-M
06-05-2005 09:21:06
 Re: How many vista G-1000 were made diesel and LPG in reply to mlansing, 06-04-2005 16:03:59
Just remember that the tack and hour meter on those vista's runs with a cable off the oil pump and when the end rounds off the hours stop counting. It is not unusual to run these for some time without the tack working before getting around to replacing the cable and many are just never fixed so the actual hours could be considerably higher. We ran one for over 5000 hours (diesel) before it needed an overhaul and they usually have seen a lot more use than 1800 hours before being left to rust away. They are very strong dependable tractors when in good condition. We have pulled the heck out of ours and have never touched anything from the clutch back on all three.
