Minneapolis Moline Tractors Discussion Forum
Piston ID help
gtg155
06-03-2005 07:35:29
I need help identifying a piston. bore is 4 1/4. Part number is ke351? What does this piston fit, an d what is the pin size and compression height suppost to be? thanks!
Kelvin
06-03-2005 08:43:54
 Re: Piston ID help in reply to gtg155, 06-03-2005 07:35:29
Off the top of my head-Those pistons should fit a 'straight block' U with a KEF engine. 'Straight block'=all 4 cylinders in 1 cast block. Should have a setscrew to retain the piston pin in the piston. Some 'split block' 283 engines used that piston too. Don't know when the change to pistons retained with spiral locks happened.
Can't help with the other specs but you can find out yourself, measuring your piston with micrometer and calipers.
