Minneapolis Moline Tractors Discussion Forum
Hey MIB 22-- More on timing cover
moli
06-02-2005 09:59:16
Those 2 covers( U-283and the G-403 power unit ) look the same to me, except the 403 has two studs on both sides of the crank nose dust cover.This 403 must have had a mag onto it cause it dont have the wormgear to drive the dist like the U has...Am I right? Do you know anything bout the cam #s I gave??U has KE-451 G...G has KE-451 H..Whats the better for pulling the 4.81 X 6.125 ( 448 CID motor)... in div 2..20% over stock rpms....thanks
MIB 22
06-02-2005 21:00:26
 Re: Hey MIB 22-- More on timing cover in reply to moli, 06-02-2005 09:59:16
That is usually the case with the mag drive they didnt put the dist drive in them. Just use the U pieces and you will be fine. I would probally send the cam to Berry cams in Minnesota and have it reground for the size engine you are building. If you want to stay with the stock grind put the G cam in just advance it a tooth.
