Minneapolis Moline Tractors Discussion Forum
minniapolis 5 star power steering
Quentin
05-31-2005 18:11:52
I have a 1959 5 Star that is pumping oil out of the vent located in the steering cylinder housing. This seems to be an atmospheric type vent and I do not know what controls the oil level in the front axle housing. Has anyone run acrossed this before? It is dumping oil out as fast as i can dump it in.
je
06-03-2005 04:29:24
 Re: minniapolis 5 star power steering in reply to Quentin, 05-31-2005 18:11:52
seals are out on cylinder
R.D.F.
06-01-2005 05:51:13
Our experience on this type problem would point to a steering cylinder problem, most likely the seals. There isn"t supposed to be execess fluids in that cavity. Dale
Kevin Moschenrose
05-31-2005 22:52:20
It maybe a couple of things different things wrongs. It could be that the control and damper valve is stuck or there is a return line pluged or pinched. I am betting on a control valve first. I have a parts book showing the break down on the valve and part numbers as well and can scan it for you if you would. My email is open so just drop me a line if you would like to.
