Minneapolis Moline Tractors Discussion Forum
G-900 3 pt problems
F M-M
05-24-2005 20:06:22
I have a 68 G-900 dsl with closed center hydraulic. The splined arms on the rock shaft only lift about to the streight out position. They lower all the way down but only lift 1/2 way up. The linkage is factory and doesn't look like any adjustment has ever been made to the ends by the paint appearance. It has the black cover over the levers and everything looks new yet. Moving the draft lever has no effect on the lift position either. What should I look for and how can this problem be corrected. Could changing the linkage to give it more through increase the lift. The lever hits the stop at about 10 on the scale like it should.
Thanks in advance for any help.
GERALD R. G.
05-25-2005 11:39:12
 Re: G-900 3 pt problems in reply to F M-M, 05-24-2005 20:06:22
the rock shaft arms may not be in the right spline on rock shaft.
