Minneapolis Moline Tractors Discussion Forum
MM U advancing cam timing ? Ask again
Texas Red
05-24-2005 16:54:18
With the rocker arms off and the timing marks lined up, whin i pull the cam gear off, do i rotate the crank clockwise or counter clockwise? I read the other post but could not figure which way to turn the crank. Thanks for the help TR
Texas Red
05-25-2005 17:09:47
 Re: MM U advancing cam timing ? Ask again in reply to Texas Red, 05-24-2005 16:54:18
OK. thanks guys. that is next on the list to do to it. will let you know if it helps. TR
Jerry Cent. Mi.
05-24-2005 17:34:37
I believe thst you back the crank up one tooth.
Augie
05-25-2005 10:33:39
 Re: MM U advancing cam timing ? Ask again in reply to Jerry Cent. Mi., 05-24-2005 17:34:37
Yep. Looking at the front of the engine - counterclockwise.
MMark
05-25-2005 13:41:48
 Re: MM U advancing cam timing ? Ask again in reply to Augie, 05-25-2005 10:33:39
On a Moline its easy to remember. Which ever you decide to turn crank or cam, you must rotate it counterclockwise.
Mark Damewood
