Minneapolis Moline Tractors Discussion Forum
445 hydraulic pump return
gary lee
05-23-2005 06:39:57
i have a DuAl loader on my 445 and my main pump when bad, so i'm thinking of using the tractor hydraulics for the loader. has anyone ever done this, and is the oil resevoir big enough, or do i need to somehow tap into the loader "tank" to get enough oil, or is it just a bad idea and i need to find a new pump.
Curt Cooke
05-24-2005 08:33:52
 Re: 445 hydraulic pump return in reply to gary lee, 05-23-2005 06:39:57
I have a loader on my 4 star and use the tractor hydraulics on it. You'll run into trouble with volume if your loader cylinders are not 2 way, that is power up and down.
gary lee
05-24-2005 14:14:44
 Re: 445 hydraulic pump return in reply to Curt Cooke, 05-24-2005 08:33:52
so do you just hook one side up as pressure and one as return and move the hydraulic control lever to pressurize the system and then still use the regular loader control valves (spool valves)? i do have two way cylinders, just wondering if i can somehow use my loader oil sump as my cyclingers leak a bit and it's easier to fill the loader sump then the tractor sump.
Curt Cooke
05-25-2005 06:38:26
 Re: 445 hydraulic pump return in reply to gary lee, 05-24-2005 14:14:44
I believe that would work but I wouldn't consider it a permanent solution. My loader has no valves included, etc. and the lift arm cylinders are powered by one of the two tractor auxillary levers and the bucket, by the other. I think you'll eventually have trouble with the use of the two sumps; perhaps all your oil will find it's way to one or the other and leave the other one dry. Good LUCK.
cURT
