Minneapolis Moline Tractors Discussion Forum
1976 2-150 water pump
Ks-farmer
05-20-2005 06:54:04
I can't get the timing shaft apart from the water pump. Is there a bolt that holds the timing gear shaft on the water pump? When I got the new pump according to the parts book there is a snap ring on it. They had a used shaft and took a look there wasn't any place for a snap ring. On the shaft there is a threaded hole in the end but the bood didn't show any bolt.
Panhandler
05-20-2005 20:16:48
 Re: 1976 2-150 water pump in reply to Ks-farmer, 05-20-2005 06:54:04
Take the front cover off the pump and unscrew the bolt that goes throught the center of the water pump shaft.
