Minneapolis Moline Tractors Discussion Forum
UTU freeze plug
jwp519
05-12-2005 19:02:40
Got a '41 UTU from a gentleman who had started to rebuild. Said it was pretty much ready to but needed a freeze plug. Can't find this in manuals anywhere - would appreciate any help as to what/where/how?
Thanks.
1951 RTU
05-15-2005 07:17:29
 Re: UTU freeze plug in reply to jwp519, 05-12-2005 19:02:40
Could a faulty freeze plug cause antifreeze to leak in cylinder #2? Would the freeze plug "break" if the block froze? Thanks in advance.
Curt
Kelvin
05-13-2005 09:12:46
Freeze plugs are those round plugs in the cylinder blocks and in the heads. I always get mine from NAPA (They have them in their PAPER catalog.) At the very least replacd the plugs between the blocks and heads. If they leak you will have to pull the part off to fix it.
old
05-12-2005 21:33:43
I use the soft plugs easyer to put in and if they come out less likely to crack the block. Only bad part is they don't look as good
Brian(MN)
05-14-2005 10:22:29
 Re: UTU freeze plug in reply to old, 05-12-2005 21:33:43
What is a "soft" plug? I thought there was just one kind. Yes, replace them all when you have the engine apart. Once I had to tear down an "R" just to replace one leaky 22 cent frost plug.
Brian(MN)
old
05-14-2005 10:41:47
 Re: UTU freeze plug in reply to Brian(MN), 05-14-2005 10:22:29
A soft plug is one with a rubber part and a bolt you tighten down. Very easy to install and also if you need to remove again.
Brian(MN)
05-12-2005 20:07:31
Freeze plugs are in the water jacket somewhere. You'll just have to find which one needs replacing, your NAPA store should be able to find them for you. They usually rust out from the inside.
Brian(MN)
Jerry Cent. Mi.
05-13-2005 05:13:02
 Re: UTU freeze plug in reply to Brian(MN), 05-12-2005 20:07:31
I would replace all of them if the blocks are off. They are about the cheepest repair on a tractor but hard to get at if its the one between the two blocks.
