Minneapolis Moline Tractors Discussion Forum
MM U advancing cam timing? why? what?
Jake Winn
05-11-2005 10:28:38
I was curious about advancing the cam timing as mentioned in an earlier post. Wont this mess up the timing of the engine, or is not a big deal. I would assume by doing this it might allow the intake valves to open earler letting more fuel/air mix in the cylinder, but what about the exhaust vavles? how will that be affected? Thanks for any help Jake
Terry Ohnmacht
05-11-2005 20:27:44
 Re: MM U advancing cam timing? why? what? in reply to Jake Winn, 05-11-2005 10:28:38
So if you would advance it you would turn the camshaft one notch counter clock wise right?
Jim Parisot
05-11-2005 17:43:36
Jake,
I think another reason one can get away with advancing the cam timing a tooth is because of the wear and slop in the valve train. After all the hours these tractors have run there is sure to be some. You may be getting it back close to original timing specs. I've heard some fellas say it's real cheap power gain on a well worn engine, and to just do it automatically if you have one like that.
Jim
Augie
05-11-2005 11:14:20
Factory cam timing was a compromise between power and fuel economy. Advancing the cam is free horsepower.
Andy2
05-12-2005 21:10:37
 Re: MM U advancing cam timing? why? what? in reply to Augie, 05-11-2005 11:14:20
If you work them in the field wouldn't the EGT's be higher? Is there a risk of burning valves?
Augie
05-13-2005 22:46:55
 Re: MM U advancing cam timing? why? what? in reply to Andy2, 05-12-2005 21:10:37
Ours are retired from farm work. They only get worked on the pulling track.
Jerry Cent. Mi.
05-11-2005 13:36:42
When this is being done is it necessary to loosen the tappet pressure to keep the cam from turning when the gear is pulled?
hobby77
05-11-2005 22:34:39
 Re: MM U advancing cam timing? why? what? in reply to Jerry Cent. Mi., 05-11-2005 13:36:42
works best to pull the gear off the crank then back the crank up one tooth then push the gear back on.
Augie
05-11-2005 15:02:05
I've never tried it with the rocker shaft installed.
RickGoodman
05-12-2005 18:44:17
 Re: MM U advancing cam timing? why? what? in reply to Augie, 05-11-2005 15:02:05
I have MM G puller with the 800 cam specs i have dynoed it both ways, advancing that cam helps both power and most of all bottom end lugging quuit a bit. the engine is a 433 cid.
Augie
05-12-2005 19:58:44
 Re: MM U advancing cam timing? why? what? in reply to RickGoodman, 05-12-2005 18:44:17
It works on the small blocks too. I've got a 206 that's bone-stock other than the cam advance in the R that I pull. It'll lug...
Rich B
05-14-2005 10:30:56
 Re: MM U advancing cam timing? why? what? in reply to Augie, 05-12-2005 19:58:44
I have a smallblock I would like to try this trick on,what is the procedure? Do you move the cam gear or the crank gear?I'm gonna have the heads of in the next week or so,Figured that would be the time to do it,Thanks Rich
Rick Goodman
05-14-2005 17:49:00
 Re: MM U advancing cam timing? why? what? in reply to Rich B, 05-14-2005 10:30:56
Remove waterpump and front cover, loosen the rockers so they wont move the cam when you take the gear off. line up the timing marks and i used a gear puller on the cam gear. pull it off ang turn the cam so it lines up one tooth over, and put the cam gear back on. make sure you go the right way.on my G i removed the radiator also to give me enough room to get to it
Augie
05-15-2005 16:39:47
 Re: MM U advancing cam timing? why? what? in reply to Rick Goodman, 05-14-2005 17:49:00
You get at the cam by removing the rocker box covers and the crankcase side cover on a small-block. Rocker arms and cam bearing caps have to come off too.
Less than two hours work start to finish...
dlp
05-15-2005 05:44:39
turn cam which way? cw or ccw
Jake Winn
05-13-2005 15:11:30
Thanks for the info. I have a 52 UTE that I am in the process of tearing the engine down for a rebuild. It was stuck when I got it. I would like to try it in a tractor pull or two and was looking for some quick and easy ways to keep it stock and boost the power a bit. I have a set of GE30T heads, and was going to bore it .040 over. I also planned on putting an M5 lp manifold set on it. Not wanting to get to far from stock for antique only pulls. Thanks for the help fellas.
Augie
05-13-2005 22:39:27
 Re: MM U advancing cam timing? why? what? in reply to Jake Winn, 05-13-2005 15:11:30
Check the link for MM cylinder head and tune-up specs.
