Minneapolis Moline Tractors Discussion Forum
UTS governor Pulling tips
Texas Red
05-07-2005 02:44:42
Hello All. Need some tips on what can be done to build the governor on a UTS to pull with. The red ones can have a different spring installed,I was wondering if anything can be done to the MM govs. thanks for any help TR
Texas Red
05-09-2005 03:19:55
 Re: UTS governor Pulling tips in reply to Texas Red, 05-07-2005 02:44:42
Guys , i need to know if there is anything i can do to it in my shop to help the uts out on pulling. this is a a do it myself project. Will a stronger spring help? Thanks for the help TR
Andy2
05-11-2005 19:01:42
 Re: UTS governor Pulling tips in reply to Texas Red, 05-09-2005 03:19:55
You can also grind some weight off the pointed end of the wieghts. Do a little at a time beause when you cut off too much they surge and loose their mid range,(goes to full open too easly).
Texas Red
05-10-2005 03:36:32
Thanks for the reply and the help. TR
Augie
05-09-2005 09:29:35
Adding a .030"-.060" shim between the spring and the thimble will improve response and give you a few more revs on top.
The big trouble with Moline governors is worn parts. Pay particular attention to the end of the pushrod and the pushrod mating hole in the lever on the output side - it doesn't take much slop here to really screw up the operation. If the thimble is rust-pitted you'll need to replace it - call Everett's.
Texas Red
05-11-2005 02:24:38
 Re: UTS governor Pulling tips in reply to Augie, 05-09-2005 09:29:35
Thanks for the help. have a second gov. and am going do some test. I will give it a try. thanks again TR
ChadS
05-09-2005 07:42:04
it might, it will speed up responce time, and keep the carb open better than stock, but, from what Ive heard about molines, its easier to have the entire governor built, vs focusing on one part alone,,, Chad
Andy2
05-07-2005 21:32:39
Give Matt at motec a call, he does a good job rebuilding them. They come back responsive and you can get more RPMS.
EdP
05-07-2005 15:27:56
Get one of them magic springs from ChadBS. Even if you put it in the tool box, you will gain 10 HP.
ChadS
05-08-2005 14:36:53
 Re: UTS governor Pulling tips in reply to EdP, 05-07-2005 15:27:56
Bout as funny as a heart attack there,,,, hes looking for info, not your BS either. Chad
Dogh
05-08-2005 15:48:48
 Re: UTS governor Pulling tips in reply to ChadS, 05-08-2005 14:36:53
What no magic springs for a MM?
ChadS
05-09-2005 07:40:05
 Re: UTS governor Pulling tips in reply to Dogh, 05-08-2005 15:48:48
LOL, Nope, they seem to run without em. Look gentlemen, I never said a spring will give 10 hp more, maybe 2-5 cause the governor is more responcive for the mods done to them, but not 10. Build the carb, the governor, distributor, etc etc, you mite find quite a bit more, I know on my ZAU, all of the above got it up to 43 hp, from 38. And yes, I got a Moline too, and its a fine tractor! Have not got around to do anything with it just yet, other than pull a disk for the garden it sits in the shed and rubs prairie gold off on all the red ones. Chad
EdP
05-09-2005 18:12:57
 Re: UTS governor Pulling tips in reply to ChadS, 05-09-2005 07:40:05
ChadBS is nothing more than a high school drop out that is living off his dad. He tell some big BS stories but has never can't prove it on the track. What was your big lie about the pulls you won? Over 1000 and you had proof? Another ChadBS lie. An IH H with 130hp but can only pull 4500 lbs class in 3rd gear? Go back to the pulling forum where someone might believe your lies.
ChadS
05-09-2005 19:04:34
 Re: UTS governor Pulling tips in reply to EdP, 05-09-2005 18:12:57
Yep got all the 25 tapes to show it, for rent! baddest IH H's in the country Ive got. damn proud of em,, deal with it. prove it? bring your tractor and find out youll have a few buck less from me taking your $$ from you getting your a$$ smoked. ChadS
ChadS
05-09-2005 18:57:48
Gonna have to put, yet another diaper on you athyrio. same Motive, same bad mouth. Just looks like you drifted west a tad,,, no longer in laffyette huh? mommy kick you out? LMAO. you have been reported, enjoy your stay. ChadS
EdP
05-09-2005 21:03:09
 Re: UTS governor Pulling tips in reply to ChadS, 05-09-2005 18:57:48
Can't handle the true can you ChadBS.
ChadS
05-10-2005 07:22:33
 Re: UTS governor Pulling tips in reply to EdP, 05-09-2005 21:03:09
EdP, how many Ip addresses can you come up with? Says you are in NY. Did not know, they allow farm tractors with in city limits there! Noise ordinances and such,,,,, Chad
ChadS
05-10-2005 06:50:41
Truth lies in the eyes of the beholder. Seems to me like maybe your the one living the lie. I dont care anymore,, have your fun, while it lasts. Chad
