Minneapolis Moline Tractors Discussion Forum
Moline U pushrod
Juston Thompson
05-05-2005 18:23:08
Looking for information or where to go to get one. Maybe someone has one laying around or knows somebody. All help is appreciated. Thanks.
Andy2
05-06-2005 17:47:27
 Re: Moline U pushrod in reply to Juston Thompson, 05-05-2005 18:23:08
What heads do you have on the tractor? there were different length pushrods for different heads as their hieght varied with compression ratios.
Juston Thompson
05-06-2005 18:08:48
 Re: Moline U pushrod in reply to Andy2, 05-06-2005 17:47:27
Oooooo oooo. Gonna have to do some more research.
JLM
05-08-2005 06:09:35
 Re: Moline U pushrod in reply to Juston Thompson, 05-06-2005 18:08:48
Justin,
Maybe you could post your engine serial number and also your chassis serial number. That would help us help you.
Also get your head number and post it here. It is stamped on the side of the head. Could be something like GE30P or 10A4210 if you have dual heads. Do you have the dual heads or the single head used in the older U's? I believe it was mid 1947 when MM changed from the single head U's to the MM engines with dual heads.. A machine shop that rebuilds engines or even NAPA can probably get you a pushrod.
Go the Fiorelli's home page at the below link to read up on MM head data.
