Minneapolis Moline Tractors Discussion Forum
minniapolis moline tractor parts needed;
olduckhunter
04-29-2005 23:43:59
hello, i have a friend that has a minniapolis moline g706 four wheel drive tractor that needs a ring gear and pinion and the nut that holds all this together for a lack of a better description. if you have or know someone that has these parts please email me at [email protected].
thank you,
wendell
Panhandler
04-30-2005 08:31:18
 Re: minniapolis moline tractor parts needed; in reply to olduckhunter, 04-29-2005 23:43:59
Does he need the front axle or rear end gears?
olduckhunter
04-30-2005 12:29:57
 Re: minniapolis moline tractor parts needed; in reply to Panhandler, 04-30-2005 08:31:18
he needs the gears for the rear end. the ring gear and pinion and the big nut that holds it all together.
thanks in advance for any answers.
Curt Cooke
05-02-2005 06:38:37
 Re: minniapolis moline tractor parts needed; in reply to olduckhunter, 04-30-2005 12:29:57
Duck, I have the ring and the nut. You can have them but that's not really going to do the job. Call or contact the Stamm's in Washington KS. If they've got one, they'll sell the ring and pinion together, as it should be. Look that differential over real good, too. Remove the ring and make sure the differential is not cracked - it's common. You may need a ring and pinion AND a differential. Might as well get it all out of the way at one time. Yes, I speak from having had the experience with a 705.
Curt
olduckhunter
05-02-2005 09:20:25
 Re: minniapolis moline tractor parts needed; in reply to Curt Cooke, 05-02-2005 06:38:37
curt, would you have a number for them? or where would i look for it?
thanks,
olduckhunter
Curt Cooke
05-02-2005 13:10:02
 Re: minniapolis moline tractor parts needed; in reply to olduckhunter, 05-02-2005 09:20:25
Classic Tractors
Clint & Kelly Stamm
785-325-2720
Good Luck
olduckhunter
05-03-2005 02:16:20
 Re: minniapolis moline tractor parts needed; in reply to Curt Cooke, 05-02-2005 13:10:02
thanks curt. i'll give my friend the info.
olduckhunter
