Minneapolis Moline Tractors Discussion Forum
MM Part # ?
Bobl1958
04-28-2005 18:38:54
I put an ad on a few days ago about some NOS MM parts I picked up. I am going to post some part #'s to see if anyone can help me with what they might fit. TW26 Wrist Pins.... Re45256 Pistons ...EE45251 Pistons...KE45351 Pistons....10A1712 Rocker Arms....9804H Exhaust Valves...EE5353 Bearings....EE5351Crank Shaft ..10A3808 Covers. Can anyone help me with what these #'s fit? Thanks very much for your help.
BMG
04-29-2005 19:49:44
 Re: MM Part # ? in reply to Bobl1958, 04-28-2005 18:38:54
EE45251 are standard bore pistons for an R. If there's a B or C at the end then they would be overbore size. EE5353 is a standard size rear main bearing for an R. If it has an A,B,C or D at the end then it's an undersize. EE5351 is an R crankshaft.
RE45256 is a set of standard bore pistons for a Z. If there's a B or C at the end then they're overbore size. 10A3808 is a battery cover for a ZB and others.
KE45351 is a set of standard bore pistons for a U. If there's a D,E or F then they're oversize.
10A1712 are rocker arms for a U and possibly others. TW26 is a standard size wrist pin for a U and possibly others.
Can't help you on the 9804H valves as that does not appear to be a Moline part # in any of my books.
Drop me an email if you want to sell any of these parts.
Thanks,
Brian
1951 rtu
04-28-2005 19:04:20
EE5353 Bearings....EE5351Crank Shaft Fit a MM R.
