Minneapolis Moline Tractors Discussion Forum
Roosa-Master injector pump
Jim Carter
04-23-2005 09:06:18
I have a M-5 diesel that I bought. The punp has been pulled apart and the two rubber cups on the
shaft is damaged. Can someone tell me where I can
get these parts or another Roosa-Master pump. Any help would be greatly appreciated. Jim
ejr-IA.
04-24-2005 08:02:28
 Re: Roosa-Master injector pump in reply to Jim Carter, 04-23-2005 09:06:18
IH dealer,JD dealer ,diesel pump shop they have or can get them.Lube them up good so they dont fold back on you when you slide the pump back on.
JK2
04-23-2005 12:43:14
If you can find a pump from a GM 5.7L or 6.2L diesel, those seals are the same. They aren't much fun to get in sometimes though. You might be better off to take it to a diesel injection shop and have them put the seals on using their tool to do it. Some pumps have a snap ring of sorts on the inside of the pump to keep the shaft from falling out.
John
