Minneapolis Moline Tractors Discussion Forum
605 in a GB
MMpuller
04-22-2005 09:44:49
What is the easiest way to put a 605 in a GB.
WCS
04-23-2005 16:15:48
 Re: 605 in a GB in reply to MMpuller, 04-22-2005 09:44:49
I have a GB with a 605. It is for sale. e-mail if interested. thanks Chris
ejr-IA.
04-22-2005 10:36:25
I put a 605 in my GVI last summer.Do you have the 4 or 6 in the GB a diesel had the long hood which you will need.I blocked up the rear end blocked the wheels,have a heavy 3pt boom for my big tractor used it to lift that big engine in and out.Used the flywheel and clutch that was in the G6 it bolted right on the 605 engine everything bolted right up.Changed the 605 from natural gas to a gas carb also mag to distributor from 425 engine.Its a powerfull tractor around 130 hp.A 403 is two cylinders short of the 605 same stroke and bore.
MMpuller
04-25-2005 09:59:23
 Re: 605 in a GB in reply to ejr-IA., 04-22-2005 10:36:25
Thanks for the information. P.S. was the carb and intake off a 425.
