Minneapolis Moline Tractors Discussion Forum
Hercules ZXB oil filter
Larry White
04-19-2005 12:35:51
I have a model V Avery with a Hercules ZXB engine. The oil filter is the add on type with oil lines attaching it to the engine. I recently purchased a replacement engine that had a filter attached directly to the block (no lines). Is this a better filter system? Does all the oil go through this filter before being circulated through the engine? If one filter is as good as the other one, I will remove the filter and cover up the holes in the block and put my old filter canister with lines on the new engine to make it more like original.
Any advice is appreciated.
Larry
Larry from MD
04-19-2005 15:34:51
 Re: Hercules ZXB oil filter in reply to Larry White, 04-19-2005 12:35:51
They should both be partial flow filters.
Kelvin
04-19-2005 19:11:07
 Re: Hercules ZXB oil filter in reply to Larry from MD, 04-19-2005 15:34:51
Mom's V has the separate canister. I'm pretty sure its a bypass-type system, because it takes at least a minute for oil pressure to begin to climb. I'm guessing the engine has to pump the canister full before the gauge reads.
