Minneapolis Moline Tractors Discussion Forum
Wiring an R
PeteNY
04-19-2005 09:50:42
Guys, lots of experience with Green, Red, and Ford, some with Case and AC, 1st time with a Gold one. Got a pretty nice RTU, needs rewired, I can muddle my way through based on experience, but would love to see a diagram just to see if anything is different, have a parts, operators, and I&T manual, and unlike other brands still haven't found a diagram, just reference to a complete harness in the parts manual, but no diagram of it. Is there one published somewhere? Thanks. Pete
BMG
04-19-2005 17:06:24
 Re: Wiring an R in reply to PeteNY, 04-19-2005 09:50:42
Pete,
I'm not aware of a published wire harness schematic for the MM R. My suggestion is to call Motec and order a replacement harness for about $50. I don't have Motec's phone # handy but I'm sure someone on this board does. If this is not to your liking then all I can offer is that the MM R wiring system is not much different than any other tractor of similar vintage.
Brian
Kelvin
04-19-2005 19:19:52
 Re: Wiring an R in reply to BMG, 04-19-2005 17:06:24
Need to know what year your R is.
'48 and before used a push-pull switch. '48 and later used 5-position ignition switch. Also, there were early 'cutout' type generators and late 2-element regulator generators.
I have a diagram for a ZA that works for R's Z's U's, etc. with the 5 position switch and 2-element regulator on the generator.
[email protected]
