Minneapolis Moline Tractors Discussion Forum
You guys can do better than that!!!!!
moli
04-18-2005 16:51:54
What the hay,I see all kinds of info on cylinder head specifications for MM but not any info on block casting numbers pertaining to what goes on what motor.Ill throw these #s at ya again..10a24286....10a10248...what do they go to...Ive had some responses but not any about these block casting #s..
Panhandler
04-20-2005 19:08:14
 Re: You guys can do better than that!!!!! in reply to moli, 04-18-2005 16:51:54
Which ones do you need? 10A24286 are 4.375 D451 blocks and 10A10248 are 4.625 D504 and D336 blocks.
JoeZ
04-20-2005 17:37:48
Just recently I had the same problem with blocks.
There was no where I could reference the cast numbers to engine or tractor model. What I did was I printed off the MM tractor pulling sight by J..... F....was his name. He had engine spefications there it told you what block went to what engine, there are no cast numbers but what it has is size of bore and stroke of engine, I was able to take these measurements and at least reference the model of tractor and engine size . The block I had did not have a cast number but after I took the measurments I found out it came from a U 302 but I was looking for blocks for a 445. This may help or may not. Letus know if it works for you.
deadeye
04-20-2005 14:49:28
Moli-----Can't help you on the numbers that you listed. I only have about 3 0r 4 parts books... Your numbers are not in them. The U's, GTB's, and 800's.....deadeye
