Minneapolis Moline Tractors Discussion Forum
Searching for site to I.D. a 150+- HP 4x4 MM Tract
Bill allen
04-18-2005 12:06:00
Anyone know of a site that could help me I.D. a 4x4 Articulated MM tractor? I couldn't find any tag, maybe it was on some of the missing sheetmetal. I need to search for parts.
JK2
04-18-2005 18:18:57
 Re: Searching for site to I.D. a 150+- HP 4x4 MM T in reply to Bill allen, 04-18-2005 12:06:00
MM serial numbers are usually on a tag on the right side of the transmission housing. If it is an MM and is articulated, it would be either an A4T-1400 or A4T-1600. The A4T-1400's had a 504 CuIn diesel. The A4T-1600's originally had either a 504LP or a 585 diesel. Some of the later ones had 800LP's from the factory and others had the same engine installed by dealers or farmers.
There are several places to get parts depending on what you need and where you are located.
John
Kelvin
04-18-2005 18:37:39
 Re: Searching for site to I.D. a 150+- HP 4x4 MM T in reply to JK2, 04-18-2005 18:18:57
Is there any chance it is a Stuttgart Tractor? If it is I'm thinking they all had separate transmissions for front and rear axles. They used a power unit engine/clutch assy, too.
