Minneapolis Moline Tractors Discussion Forum
G overbore correction
moli
04-08-2005 17:11:31
Whats the biggest G moline overbore piston i can get without getting custom pistons made.Also what other pistons will fit...m5,g1000,m670.? And do they come in bigger bores? sorry meant to say m670 not m5 two times..on last post...
Don Livingston
04-13-2005 11:30:02
 Re: G overbore correction in reply to moli, 04-08-2005 17:11:31
I have a new set of M/W 4 3/4 pistons for $550.00
Don L.
Ph 507 433 0073
JLM
04-09-2005 18:56:37
Factory bore on MM 403-4 G engine:
Factory bore is 4 5/8. It can be bored to 4.81 safely, but 4.75 is good too.
4.81 is the largest bore you can go to and not have any problem with too little material left in the block. all WELTER'S in Verona, Missouri for PISTON'S and advice. They have a 4-3/4" and a 4.81" Ph # 417-498-6496.
They sell a lot of Moline stuff and used to do a lot of pulling.
