Minneapolis Moline Tractors Discussion Forum
Seat Shock Absorber
Dennis in Ontar
04-05-2005 16:44:57
I have a 53 ZAS that currently is missing the shock absorber that goes under the seat and has a small coil spring which sits independently outside of the shock. Can anybody tell me what the part number might be for the shock or where I might order one? Thanks in advance.
Dennis
cliff
04-06-2005 22:15:44
 Re: Seat Shock Absorber in reply to Dennis in Ontario, 04-05-2005 16:44:57
Dennis, the seat assembly i have is on a minneapolis moline 445 universal that i am fixing up. my email is [email protected]
Kelvin
04-05-2005 18:40:55
All the moline seats I've seen have the shock absorber inside the coil spring. They also have 4 parallel bars between the seat and its mount that allow the seat to pivot. The shock/spring assembly sits between the bars.
The way you describe yours, it sounds like aftermarket. If its like I'm thinking, it sounds more like what was used on some Farmalls and Internationals.
Dennis in Ontario
04-05-2005 19:37:28
 Re: Seat Shock Absorber in reply to Kelvin, 04-05-2005 18:40:55
Thanks for the reply Kelvin, l will take a better look at it tommorow and leave a message.
Kevin Moschenrose
04-05-2005 22:54:00
 Re: Seat Shock Absorber in reply to Dennis in Ontario, 04-05-2005 19:37:28
If you need just the shock you can go to your local golf cart place and pick up and pretty close match to what you have. They work quite well.
cliff
04-05-2005 23:06:45
 Re: Seat Shock Absorber in reply to Kevin Moschenrose, 04-05-2005 22:54:00
i have the whole assembly used. if you are interested email me.
Dennis in Ontario
04-06-2005 16:56:17
 Re: Seat Shock Absorber in reply to cliff, 04-05-2005 23:06:45
Hi everyone and thanks for helping me out. Today l found more information on the seat from my No. R-1072d repair catalog. It is the group 2 seat also known as Flote-ride. The M.M. parts number is 10B2036 which consits of a cotter and GM120123. Does this information still agree with what you guys thought? Cliff l would e-mail you a) if l had your adress and b)is the assembly you are talking about from a golf cart or tractor seat ? Thanks for all this info. guys.
Kevin Moschenrose
04-07-2005 00:19:11
 Re: Seat Shock Absorber in reply to Dennis in Ontario, 04-06-2005 16:56:17
The shock absorber is "only" the shock from the supension on the axles of the cart.
Dennis in Ontario
04-11-2005 17:22:39
 Re: Seat Shock Absorber in reply to Kevin Moschenrose, 04-07-2005 00:19:11
Once again thanks Kevin. Till next time.
