Minneapolis Moline Tractors Discussion Forum
MM 3 pt plow model?
Ks-farmer
04-04-2005 20:17:30
Saturday I aquired a moline 4 botton 3 pt. plow and the beams are made of pipe and the hitch is cast steel. Inside the hitch has a pair of rubber cylinders for bumpers. The tail wheel is mounted on square tubing with holes in it to set the depth. Please let me know what model number of plow I have, I haven't ever seen another one like it. The hitch also has MM cast in the hitch and MM cast in the pipe caps.
grandfield
04-04-2005 20:47:02
 Re: MM 3 pt plow model? in reply to Ks-farmer, 04-04-2005 20:17:30
What you are describing is the M series plow. The 4 bottom is the M1400, Don't recall seeing a tailwheel like you describe, but haven't seen a 4 bottom. I have a M1300, 3x14" and it has no tailwheel and no gaugewheel, relies on the 3 point to set depth. You can find literature on ebay once in awhile. I have literature on them, but am leaving for Iowa in a couple of hours so don't have time to look up that tail wheel. Maybe when I get back, IF I remember!!! grandfieldfarm1 at aol.com John
