Minneapolis Moline Tractors Discussion Forum
1950 mmz build
moli
04-03-2005 08:05:03
What mods can i do to get more power out of her, not alot, say 20 hp or so.Also will mmu hydrolic pump and resivor tank fit her??...thanx
Mopower
04-04-2005 06:13:04
 Re: 1950 mmz build in reply to moli, 04-03-2005 08:05:03
Bore it to 4.81 and buy aluminum pistons from Welters or Everetts. Install an LP head (good luck finding one). Use and LP intake and a ZT exhaust. Open up and smooth out the air flow. Chevy 350 exhaust valves work great for a rebuild. The right cam helps too, but it's tought o get one that works really well with that engine. You should be able to make 60 h.p. A governor kit from Richard Kenyon would convert it to a Pierce governor. That would do wonders too. If you got real ambitious, just bold a U302 engine in there. They run 55-60 h.p. stock.
