Minneapolis Moline Tractors Discussion Forum
deck plate for moline engine
tmt
04-02-2005 09:18:22
whendel says he has sold these plates befor but can not find the no. info for them can anyone help
ChadS
04-07-2005 17:50:54
 Re: deck plate for moline engine in reply to tmt, 04-02-2005 09:18:22
I can make them if I had a pattern. Steel, or copper, could make a few out of copper and use like shims,,, Chad
ChadS
04-07-2005 17:50:48
Andy2
04-05-2005 21:07:17
sorry, I reread your post and saw it was for the engine. If you are talking about the plates that fit between the block and crankcase to run 336 pistons and blocks on a U or adjust deck hieght, you can use several sets of block gaskets to to the same thing. You can trace a block gasket on a piece of steel and plasma cut it so it doesn't warp too bad.
Shawn W
04-03-2005 13:29:40
I got 2 that came out of a GB that we tore apart and worked over 2 years ago, really dont wanna sell them unless they go with the blocks and pistons as a set, but i would be willing to make you a card board pattern and you could cut one out of steel on your own
thanks
Shawn
Ks-farmer
04-04-2005 18:50:12
 Re: deck plate for moline engine in reply to Shawn W, 04-03-2005 13:29:40
What do you mean by a deck plate? Something to cover the pistons?
Andy2
04-02-2005 12:58:10
If you are reffering to the diamond floorplate, it would be easy to fabricate. You could have a shop with press brake bend you one up from a piece of 7 ga deckplatting,(diamond tread).
